Hello, I tried to convert my PAL VHS to NTSC VCD/MPEG1 format. I captured the video at 352x576 using Huffyuv compression,and with these commands in Avisynth script : 1.avisource("c:\capture.avi"),2.complementparity() ,3.separatefields(). I then opened this script in Virtualdub,add Donald Graft's SmartBob filter,and add Precise Bilinear resize to 352x240,retain the 50 fps, and save the AVI with Huffyuv compression. I then opened up this AVI in Aftereffect 5.5,set the composition setting's fps to 29.97, and performed frameblending. It took so long to render,and the final AVI were filled with so many blurring,especially when there're lots of motion. Is there any other way to frameblend 50 fps movies to 29.97 fps faster without producing too much motion blur, perhaps with Avisynth or Virtualdub ? Thanks a lot for the advice.
If you want to go advanced the try the following...
In the avisynth script as the last line as
ChangeFPS(23.976) or is it AssumeFPS(23.976)
Basicly you will be slowing down the video, but it will be very crisp. 23.976 is a valid NTSC VCD FPS. -
You can try Dynapel MotionPerfect (http://www.dynapel.com) to convert the framerate. Canopus Procoder is also good at convert PAL to NTSC. You can also do it in TMPGEnc. I've never tried it myself...
Ronny
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 11:33 -
PAL video on NTSC HD TV Best motion Playback
By Deter in forum RestorationReplies: 7Last Post: 25th Aug 2011, 05:34 -
How to convert a PAL VHS into NTSC VHS or DVD?
By coody in forum Video ConversionReplies: 9Last Post: 22nd May 2011, 02:09 -
Best tool for PAL to NTSC without jerky motion...using TMPGenc
By funkymix in forum Video ConversionReplies: 3Last Post: 15th Mar 2009, 11:59 -
motion blur on tv
By ineedhelp007 in forum Newbie / General discussionsReplies: 3Last Post: 18th Dec 2007, 10:49
