  1. I encode with TMPGENC.
    But even a created mpg of 2.77 GIG, won't fit on a DVD,
    using the program MYDVD.
    Does someone know how to fix the problem,
    or does someone here have a better template for encoding?
    CYA DVD DUDES
    ( . Y . )
    Apr 2002
    Florida
    first if you encode with CCE you will be able to control the final output size as you want. and even outside of that 2.77GB will fit on a dvdr
  3. MyDvd will re-encode the audio into PCM which is uncompressed. This may be why it says it wont fit. You should try a DVD authoring program that supports MP2 audio such as Dazzle DVD complete or (I Think) Ulead DVD workshop.
  4. quite a few authoring programs except at least 2 channel ac3, maybe the full 6 channel if your lucky, try DVDit, scenarist etc..
