I have WinXP, WinTV card and am capturing VHS from old camcorder.
I can't seem to manipulate the source stream in VDub. That is, I cannot set the brightness, for example. The dialogue with brighness (and other parameters) comes up but the controls (sliders for brightness) are locked.
Nor can I set the source type (my camcorder is NTSC, so I need to
tell VirtualDUB this?).
I have tried the bundled Movie Maker app. There I can set the
brighness, camcorder type etc (interestingly, these settings are then
used by VirtualDUB next time I open it).
I ate a grizzly bear for breakfast. -
Try loading a filter named brightness/contrast to adjust your brightness.
Hello. -
In VirtualDub go to, Source, Device settings. You set the brightness for the driver there. If they are locked you must have a driver problem.
Thanks for the ideas.
Where do I set the source type, specifically NTSC vs. PAL?-----------------------------------------------------
VirtualDub missing compression codec options?
By raena in forum Newbie / General discussionsReplies: 15Last Post: 9th Sep 2015, 20:47 -
kmplayer, how do you set the brightness/gamma ?
By vhelp in forum Software PlayingReplies: 1Last Post: 25th Sep 2011, 16:04 -
Should I use Virtualdub filtering options with a M2TS file ?
By rds11 in forum Video ConversionReplies: 2Last Post: 4th Jul 2010, 16:50 -
Virtualdub Compression Brightness Problem
By ZZen in forum EditingReplies: 8Last Post: 14th Aug 2009, 17:10 -
No 48kHz options in MPEG-Layer 3 in VirtualDub and Mod
By ashwin.terminator in forum AudioReplies: 24Last Post: 6th Apr 2009, 15:07
