I hear there is a trick to make my player play SVCDs thinking they are VCDs
Anyone care to explain to the newbie?
Thanks![]()
With Tmpeg ( MPEG tools ):
demux the file into a video and an audio ( simple demux )
then
make simple mux of your two files with a MPEG 1 header ( important to check it before starting the process )
It s a fast process ( with a "current PC" )
Finally , Burn a CD with Nero ( Video CD )
( desactivate standard compliance )
Your CD will behave and taste like a VCD ! but it's a SVCD
I have tried 352*288 resolution ( VCD PAL resolution ) and 480*576 ( SVCD PAL ) it works.
Bitrate usally from 1500 to 2500 ( not tried higher )
It works fine on my Sony DVP NS 305 ( not SVCD compliant )
I ve tried to burn SCVD files on a nero VCD but without the demux-remux trick , it freeze .
Is anybody tried other resolution / bitrate that works fine?
thx Cyrille -
absolutely !
using Tmepg .
usally I convert a single DivX into 2 VCD ( or SVCD )
bitrate 1500 bps to 1700 bps for a 1h30 to 2h movie
don't forget to adapt resolution if necessary
PAL 480 x 576 pixels 25 frames/second
NTSC 480 x 480 pixels 29,97 frames/second or 23,976 frames/second
for standard rez.
cause somme DivX have strange resolution not compliant with all DVD players.
Sony DVP-SR200P -- Playing CDs In Repeat Mode Without a TV
By maico996 in forum DVD & Blu-ray PlayersReplies: 3Last Post: 18th Jun 2012, 15:57 -
My Sony DVD player SONY DVP- NS718 H
By samyer in forum Newbie / General discussionsReplies: 1Last Post: 3rd Feb 2010, 00:56 -
sony dvp-ns708h
By mrmag in forum DVD & Blu-ray PlayersReplies: 4Last Post: 26th Jan 2009, 21:13 -
Sony DVP-NS601HP ??
By jjfromm in forum DVD & Blu-ray RecordersReplies: 1Last Post: 29th Dec 2008, 13:02 -
HELP !!! Please !! Sony DVP-S7700
By adamsj13 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 14th Oct 2007, 05:04
