I downloaded a movie SVCD and ended up with 2 BIN/CUE files.
I tried to load the Cue file into VCDGear, I edited the cue file, but kept getting the message that the file could not be found.
I burnt the Cues using Nero all well and good on the first part but after burning the second part, I opened it in Media Player, Media Player was saying that the movie is over 4 hours long!
When I play the second part it breaks up into blocks and freezes.
I then tried to convert the AVSEQ file from the CD straight into VCDGear but it would still not find it.
I tried to load the AVSEQ file into TMPGEnc to encode but keep getting the message unsupported.
I have read through the forums but can’t find a cure.
I am trying to fix the second part, can it be repaired?
I would like to convert the movie to DVD but the files are not recognised.
Results 1 to 1 of 1
I will never learn
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 15:25 -
Can you burn a CD-extra using .cue file?
By piano632 in forum AudioReplies: 3Last Post: 15th Feb 2009, 21:45 -
Having trouble with .bin/.cue files
By UncleBose in forum Software PlayingReplies: 8Last Post: 12th Jan 2008, 06:06 -
cue sheet problem
By Snowcrystal in forum AudioReplies: 2Last Post: 2nd Sep 2007, 12:29 -
cue,bin converting to dvd?
By zziem in forum Newbie / General discussionsReplies: 5Last Post: 7th Aug 2007, 10:36
