i was looking at tv episodes and i came across some divxs that were only 141mb and 43 minutes long.. so i tried capturing one of my own using the how-to guide on vcdhelp.com using virtualdub but when i got to video/set custom format, "YUV2" wasn't an option.. does anyone know why?
i used UYVY because it was the default with the DivxLow motion codec and it used about 17mb/min so I was wondering if that had anything to do with the format..
does anyone know what settings i should use to make small low divxs? do i have to capture to avi and convert? any help would be appreciated.. thanks
as far as i know is YUV not a codec.
when you 'save as' dixv there should be options where you can set the quality (crispyness and bitrate).
i use uiVCR and that works ok.
Question - Capturing to MPEG directly with VHS cropping
By joejoe in forum Capturing and VCRReplies: 2Last Post: 24th May 2009, 23:45 -
printing directly to cd or dvd
By Ogilvy in forum LinuxReplies: 4Last Post: 5th Mar 2009, 09:57 -
Capturing from VHS to divX: Recommendations (Flicker & freezing proble
By roylayer in forum Capturing and VCRReplies: 2Last Post: 26th Sep 2008, 18:00 -
Directly edit a video?
By thunderdraco in forum Newbie / General discussionsReplies: 1Last Post: 6th Feb 2008, 22:21 -
Directly ripping hardcoded subs on DivX/AVI from DVD
By drstupid in forum SubtitleReplies: 2Last Post: 4th Jan 2008, 16:51
