..this seem not to work. I have PowerDVD XP, and whenever trying to open either the IFO or the VOB from the HD (ripped with smartripper) it shows up only green background & some funny squares, like a DVD would be damaged.
Is this my problem only or typical???
Thx for your help!
Michael
Did you place all the ripped files in a folder on your hard drive named "VIDEO_TS"...? I believe that is a requirement for playing raw VOB files through a software DVD program usually. You could use Sasami2k, but the audio would likely sound strange.
HUN-YA!
Akai Rounin -
Try WinDVD in latest version. This worked without problems, playing vobs ripped with smartripper.
Sounds to me like the VOB's are still encrypted. Did you try playing the DVD before ripping them ?
Select "Open > Media Files"Originally Posted by mhuelsew
Add all the Vob's to the list, click OK
If that is giving you problems, try loading one of the VOB's into TMPGEnc > Browse *.* > Vob 1 > Preview
Make sure Smartripper is set at demcrovision
How to open ripped bluray in powerdvd 12?
By mason dixon in forum Blu-ray RippingReplies: 1Last Post: 1st Mar 2012, 13:26 -
PowerDVD DX - Problem playing BluRay
By cdrake261 in forum Software PlayingReplies: 1Last Post: 24th Apr 2010, 16:46 -
PowerDVD versions for playing BlueRay?
By W_Eagle in forum Software PlayingReplies: 12Last Post: 15th Apr 2009, 20:43 -
Playing HD-RIPS (.evo files) with PowerDVD
By tomkat in forum Software PlayingReplies: 2Last Post: 19th Jan 2008, 16:24
