Hello
I want to delete or to correct manualy something in my video file (.avi file). You know, to delete a light or a reflection or to correct a color in a specific point etc like editing pictures in Photoshop. Adobe's Premier has only effects and transitions, you can not interfere the video itself. Is there any solution ? I shot a gallery and becouse the artwork was behind glass I want to delete tha reflections of the light. Thanks
That sounds like it might be some frame-by-frame and (nearly) pixel-by-pixel editing. How long is the portion of the video where you want to do edit out the reflection? Do you have the opportunity to reshoot it with better lighting control?
As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
i've never seen regular software that can do that, so i guess that's gonne be VERY expensive 'hollywood stuff'...
Video editing software that supports importing video with multiple audio?
By elgy in forum Newbie / General discussionsReplies: 5Last Post: 15th Nov 2011, 19:32 -
Webex recording changes video to side panel. Can I edit with video editing?
By Teenotes in forum Newbie / General discussionsReplies: 0Last Post: 2nd Jul 2011, 12:32 -
Video Editing Software: mkv, h264 & DTS Editing?
By techdls in forum EditingReplies: 8Last Post: 28th May 2011, 01:29 -
Video editing programs letting you create .m2ts files with VC-1 video?
By justin0324 in forum Authoring (Blu-ray)Replies: 1Last Post: 17th Mar 2009, 22:24 -
Is there a video card that can handle both: gaming & video editing?
By randyannie in forum Newbie / General discussionsReplies: 11Last Post: 20th May 2007, 15:50
