I am wondering what in the heck am I doing wrong?
I set up three files to be converted to MPEG using TMPGenc using the Batch in the program, when I launch the batch only the first one on the list gets done & then the program stops
Any ideas why I would have this problem?
Thanx
"Computers are stupid, but they are capable of being stupid one million times per second"
As far as I know TMPGenc doesnt do batch encoding properly, you want to use xing encoder for batch.You can do as many as u want and they will encode one after the other.Xing is also the fastest encoder I've ever used
Tmpgenc has problem to encode audio. It happens to me quite often that the program shuts down after encoding audio. You can encode audio first and batch encode video, you won't have any problem.
Batch "file creation from a text file, Placed into a created directory
By Muther in forum ProgrammingReplies: 5Last Post: 24th Sep 2015, 19:29 -
Tmpgenc Plus & TMPGEnc Batch List Creator help Please
By VOYAGER2009 in forum Video ConversionReplies: 2Last Post: 4th Jul 2010, 08:57 -
Mediacoder & Batch conversion
By Serville in forum Video ConversionReplies: 0Last Post: 8th Jul 2009, 18:28 -
Audio out of sync, Batch DVD Steam Converter & Muxman
By assman24 in forum Newbie / General discussionsReplies: 3Last Post: 5th Dec 2008, 17:25 -
Help.... Conversion & Author Problem with TMPGENC Xpress V.4.4.1.237
By milindb1 in forum Video ConversionReplies: 19Last Post: 22nd Sep 2008, 03:40
