I just ripped a DVD with DVD2SVCD for the first time and it made a wonderful SVCD .. BUT.. the sound starts before the movie begins!.. That makes the entire movie have the sound out of sync by a constant 6 seconds.. Is this preventable? Maybe it was just that DVD that has an awkward sound track???
I'm having the same problem can't figure it out some new programs within the bundle I have never dealt with.
I had one of those...I didn't rip the first chapter and it solved the problem...it was a rudolph misfits dvd. Yes you can manually try to correct it (good luck it's advanced) screw around with the bbmpeg startup delay settings. See dvd2svcd advanced reference.
To correct this, decode your audio to a .wav file and add 6 seconds of silence at the start of it with a wave editor program. Save this and re-code it to MP2 with TMPGenc (use a jpg image as a video source file). Once this is done, demux it, and then remux the new soundtrack with the original video file and this should give you pretty decent sync.
delete sound between x seconds and y seconds?
By charlieship in forum Newbie / General discussionsReplies: 3Last Post: 4th Jun 2011, 23:14 -
MPC-HC ,MKV Video and Sound skips every 6-10 seconds.
By Crucio in forum Software PlayingReplies: 8Last Post: 18th Jan 2010, 21:29 -
XBOX 360 HD-DVD sound popping when HD-DVD starts only with HDMI hookup
By vatkat234 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 15th Jan 2009, 21:03 -
Movie will hang for a couple of seconds while streaming to the 360
By merc36 in forum Newbie / General discussionsReplies: 5Last Post: 4th Jan 2008, 12:30 -
Cyberlink PowerDirector 6 - DVD starts playing after 8 seconds
By gayclarke in forum Authoring (DVD)Replies: 1Last Post: 24th May 2007, 01:00
