software for DVD's, I would like to copy a DVD movie to a blank DVD RW disk, most of hat I have seen is for VCD and SVCD but not much DVD. What is the best and "easiest" guide for getting a DVD movie copied to a RW DVD disk? I'm a newbie, and have actually read quite a bit (the more I read the worse it gets) any help is greatly appreciated.
You want easy,open Smartripper,it will tell the size of the "movie" file. If you very lucky and it's 4370MB or less,than just rip in backup mode. Then drag the VIDEO_TS folder it created to your burning software. Anything else gets complicated.
Beauty&Beast Blu-Ray Ripping Loses 3-Dimensionality after ripping
By KostaRae in forum Blu-ray RippingReplies: 4Last Post: 22nd Mar 2011, 05:50 -
dvd episode ripping? can't find hole file.
By David9799 in forum Video ConversionReplies: 6Last Post: 23rd Aug 2010, 09:20 -
Help me find the right solution please.
By abeaty in forum Video ConversionReplies: 8Last Post: 7th May 2010, 23:12 -
Where to find SUBSYNCH
By Wan Dat Ting in forum MacReplies: 3Last Post: 18th Jul 2008, 20:15 -
A ripping software that you can pick what you're ripping?
By twells22 in forum Newbie / General discussionsReplies: 4Last Post: 6th Feb 2008, 10:22
