I can make good VCD's, but when I make SVCD's they play soooo slowly. What can I do to make them play properly.
Capture Card: ATI 64 Meg DDR VIVO, Analog VCR as input. I have tried many things, but no soap. Your help will be appreciated. Using Cue/Bin CDRWIN does not help either.
Have you installed both patches (from the ulead site) for UVS6?
As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
Uleads has a problem with their SVCD system and ATI video cards. However, there is a work around for ATI users. Just use the ATI capture and bring in the clips using "select template from existing video file." You can Cue/Bin or use Ulead's SVCD wizard in the finish mode.
Poor Picture quality - need help!
By Martin747 in forum EditingReplies: 2Last Post: 26th Dec 2010, 13:00 -
Poor man's 5.1
By Haopengyou in forum Media Center PC / MediaCentersReplies: 0Last Post: 18th Nov 2010, 08:53 -
Poor Burning Quality
By CindyLuB in forum DVD RippingReplies: 6Last Post: 17th Jul 2010, 21:41 -
Poor VHS or Poor VCR?
By ryangarfield in forum RestorationReplies: 10Last Post: 7th Jun 2010, 07:34 -
Poor Quality
By Net_Bug in forum Capturing and VCRReplies: 3Last Post: 29th Mar 2008, 17:37
