When I try to write my Divx file with Nero the program says that it is anb invalid Avi file although I can play it with media player without any problems.
What could be wrong?
Should Nero be able to convert a Divx file to an MPEG by itself and then write it to a disk?
Djnick,
I don't own Nero so I don't know, but I would expect that it shouldn't be able to convert a DivX to VCD format. DivX is MPEG-4, and VCD uses MPEG-1.
Go to www.tmpgenc.net - I swear by this encoder. Follow the wizard, put in your Divx, select where you need to split it (a VCD holds up to 74 minutes of movie) and hit encode. You can't go wrong with the wizard. Once you have your file, use Nero to burn it as a VCD!
In TMPGEnc, it is always worth using the noise reducers etc in my opinion, as it seems to give better quality.
Any more questions, just shout.
CobraDMX -
I have tried to convert with that program but my mpeg's turn out pitch black and without sound!
Please read the following link
www.vcdhelp.com/tmpgenc.htmMay the force be with you.
Convert A DivX with AC3 To VCD
By Stinky in forum User guidesReplies: 43Last Post: 23rd Jul 2011, 03:55 -
VCD to Divx conversion
By silverarrow in forum MacReplies: 14Last Post: 18th Feb 2010, 08:25 -
Divx to VCD
By d_unbeliever in forum Authoring (VCD/SVCD)Replies: 16Last Post: 30th Apr 2009, 00:19 -
VCD to DIVX Conversion
By DarkPhoenix77 in forum MacReplies: 2Last Post: 16th Mar 2009, 12:28 -
DiVX (AVI) to (S)VCD using DVD2SVCD
By LeeBear in forum User guidesReplies: 125Last Post: 4th Jul 2008, 17:01
