hi guy's
is it possible to burn a svcd with ac 3 or do i just burn it like a divx files or something and play it only on my pc ???
any help is appreciated
thanks
Rodimus.
You can multiplex an ac3 file with a svcd compliant mpg file, but then of course if you burn this it will not be a compliant SVCD and no hardware dvd player will be able to play the audio. You could still play it on your pc though, yes.
You can use bbmpeg to multiplex ac3 and m2v streams. -
If you want 5.1 Audio from SVCD in general, I suggest that you look at the other thread in this forum which discusses MPEG Layer II multi channel in depth.
Regards,
Ralf
3d video with dts sound how to convert to ac3 sound
By fredddiemercury in forum Video ConversionReplies: 4Last Post: 2nd Nov 2011, 14:54 -
no sound on dr. divx ac3
By jwdove in forum DVD RippingReplies: 1Last Post: 25th Jun 2008, 04:07 -
No sound when playing AC3 files...
By GangstaRap in forum AudioReplies: 1Last Post: 9th Feb 2008, 23:21 -
AVI with AC3 - No Sound
By Degradation in forum AudioReplies: 0Last Post: 19th Dec 2007, 16:28 -
MPEG-2 With AC3 Sound on DVD
By crazynewfie in forum Newbie / General discussionsReplies: 2Last Post: 16th Sep 2007, 12:53
