I have Pioneer 104 and I tried to burn my first DVD-RW (Princo).
Though the "Job Was Done" (I used Primo DVD 2.0) both my DVD-ROM
(also Pioneer DVD-500m, 116 series) and my burner cannot read the DVD-RW. I use Win XP Pro. Can Anyone Help Me? Maybe I must change the recording options? I use:
UDF with Joliet-106 characters length-plus 8+3 tree (bridge)
I just received a pack of 100 Princo DVD-RW's today. I have successfully been using the Pioneer DVD-RW, which came with my Cendyne (relabeled Pioneer 104), as a "test disk" with my set-top players (APEX and Panasonic DVR30). Nero settings are the same for DVD-RW as DVD-R. (Except, of course, erasing the used RW's before re-burning). I burned my first Princo today, and had the same problem you did (not readable, or even recognized as media, on my reader, burner, or set top players). I didn't have a chance to try another yet, and I am seriously hoping that it was just one bad one. I have been using Khypermedia DVD-R's (from OfficeMax) and have not had a single bad one yet (of about 50 burns).
If you have been able to create and read a DVD-R, then a DVD-RW should also work when created on the same drive.
I have the Pioneer and it works fine (don't have Princo, but have tried 2 other brands). You do need to Erase them prior to reuse.
K-Lite Codec Pack messing up burning IMG audio cd burning
By Blå_Mocka in forum AudioReplies: 24Last Post: 26th Aug 2010, 05:27 -
1. Need advice: Burning DVD from Flash Drive mP4 2. DVD-R vs. DVD+R
By Ronald Vaughan in forum Newbie / General discussionsReplies: 1Last Post: 14th Jul 2010, 14:53 -
Iso burning faile, folder burning succeed
By cd090580 in forum DVD & Blu-ray WritersReplies: 5Last Post: 3rd Dec 2009, 14:46 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 13:14 -
Advantages - disadvantages to burning video folders or burning an ISO img
By theewizard in forum Authoring (DVD)Replies: 14Last Post: 26th Jun 2007, 15:19
