INVALID VIDEO SOURCE.........This is just one of the many error messages I get when trying to load AVI's and MPEG's into TMPGE. As soon as I try to convert most things to MPEG I either get that message or one that it... "can not open......or unsuported"......I'm Trying To Learn!!!!!!..Really!!!!
Hi:
Sorry, I am not an expert in this, but sounds like you need to download the Nimo Codec pack.
If not I know someone here will help you soon!!!!
THX
8)
Rey -
Hi:
I also read in some of the post here that you should increase the priorty of your VFAPI plug-in in Enviromental Setings in the Options Menu.
Increase them to a high priority. It is supposed that you should increment them a number or two and should not increase them too much.
Try this. If you still can't, keep posting here. I know there will be one of the wisemen who can help you.
"Did you hear me Wisemen"
8)
Rey
P.S. Did your files play OK in Windows Media Player? -
Unsupported files, means just that, your system does not have what it takes to edit those files. As you have already downloaded and Installed the Nimo codec pack, I suggest you try to open the AVI in Vdub
File > File information should tell you the audio and video codec's that were used, However Nimo has them all anyway, well almost... it don't have the fake codec for the fake movies
Change the VFAPI in TMPGenc. Go to Environmental settings -> VFAPI plugin and increase DirectShow Multimedia File Reader to 4.
YOU GUYS ARE THE BEST!!!!!!!.....I changed the enviromental setting and that cleared up almost every error I was getting.......THANKS!!!!!!!!
How to improve video quality of *.3gp video source
By vain in forum Newbie / General discussionsReplies: 1Last Post: 29th Nov 2009, 04:00 -
multicamera video montage with different source fps and video formats...
By foler in forum EditingReplies: 2Last Post: 16th Feb 2009, 05:19 -
Mux: invalid video error .Impression DVD pro 2.2
By KYOPOWER in forum Authoring (DVD)Replies: 0Last Post: 24th Sep 2008, 14:58 -
Impression DVD Pro Problem "Mux: invalid video error&qu
By Kippo in forum Authoring (DVD)Replies: 1Last Post: 24th Sep 2008, 12:47 -
invalid audio and video files
By volam in forum EditingReplies: 1Last Post: 20th Apr 2008, 04:57
