When I try to encode the sound in VirtualDub it always crash. I can only use direct stream copy. Do anyone know what the problem could be?
Also when I select mp3 compression I can only choose 56kBit/s, 24,000 Hz Stereo as the best quality. It should be at least 128kBit/s and 41,000Hz
Sounds like you have a lot of missing codec's, Install the Nimo codec pack, that will give you a MP3 professional codec with a better range, as well as DivX Mp3.
Your other problem will probably go away also after you install Nimo
http://nimo.everwicked.com/ http://perso.wanadoo.fr/nimo/
VirtualDub - Editing and Fixing Sound
By bpatters69 in forum EditingReplies: 1Last Post: 26th Oct 2009, 13:33 -
problem with divx with newer virtualdub and virtualdub mod
By goingape in forum Newbie / General discussionsReplies: 9Last Post: 26th Mar 2008, 18:08 -
Virtualdub and sound problem
By Shabaman in forum Capturing and VCRReplies: 0Last Post: 29th Feb 2008, 09:55 -
Virtualdub used with or without AviCutter=Sound Synch Problem
By johnharlin in forum EditingReplies: 11Last Post: 29th Dec 2007, 12:13 -
VirtualDub can't decompress the sound.
By KOJV in forum Newbie / General discussionsReplies: 5Last Post: 12th Jun 2007, 19:59
