i have just downloaded "a bugs life" and its fine untill near the end the audio goes out of sync...its fine at the beginning..is there an easy way to fix this? i have read the help files on this and it looks complicated and also because the sync goes towards the end it looks like it will be hard for me to do "trial and error" as it will take ages to get to that point of the movie.
Any suggestions?
Chris
No, it is not too complicated. Remember to fix your problem only takes a few steps. Measuring both the audio and the video, and stretching the audio to fit the video. Keep this in mind as you re-read the guide. Do not give up!
Hello. -
Since it seems by your post you have audio drift or gradual audio synch (sic), try this one first:
http://forum.vcdhelp.com/userguides/78944.phpHello.
Audio has problems in Windows Media Player but not in other audio apps
By brassplyer in forum Software PlayingReplies: 7Last Post: 23rd Sep 2011, 16:12 -
audio problems...............
By themediaman in forum Video Streaming DownloadingReplies: 6Last Post: 25th Dec 2010, 17:43 -
Problems with Audio
By fi3ryfalc0nZ in forum Software PlayingReplies: 3Last Post: 7th Dec 2009, 18:23 -
audio problems
By minigamer in forum Newbie / General discussionsReplies: 1Last Post: 21st Dec 2008, 11:03 -
Audio Problems
By macuser1960 in forum ffmpegX general discussionReplies: 9Last Post: 26th Feb 2008, 14:46
