Want to display jpegs on JVC 500BK, I have just bought one. I see that the display time is very slow, as inidicated in the reviews, and indeed when I put a CD in with jpegs it is slow.
However, my jpegs are all about 2megs in size. I am guessing that if I coverted them to 640 by 480 that the speed of display would be much fast, and that if I used very little or no compression that this would also help in the speed and the quality, I also guess that since the best resolution for TV viewing is NOT greater then this for NTSC and S Video. - That 640/480 will be about as good as you can achieve?????
Is the above correct or am I missing some point(s) here??
Any help is appreciated, I don't want to do this several times over.
PS what is BBCode???
Current Project is to convert many slide and photos to DVD, SVCD etc.
The higher the resolution the better the picture(4:3 offers best results).Also use .bmp if given the choice,as it is uncompressed.
JPEG to YUV
By mma238 in forum Video ConversionReplies: 20Last Post: 3rd Apr 2011, 12:53 -
M-JPEG codec
By cheerful in forum Software PlayingReplies: 1Last Post: 3rd Mar 2010, 19:43 -
Help putting jpeg on a dvd!!
By ksorvick in forum Newbie / General discussionsReplies: 1Last Post: 24th Nov 2009, 15:02 -
jpeg to PDF is OK! But PDF to jpeg?
By bryankendall in forum ComputerReplies: 2Last Post: 14th Sep 2008, 16:53 -
Need advice on making dvd copies and making ISO files please.Thanks!
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 1Last Post: 17th Jan 2008, 13:03
