I rendered a bunch of separate clips in VV3 and imported them into DVD workshop 1.2 to author. (Usually I would render all into one big mpeg out of VV3, but this was an experiment). I didn't create a menu and set DVD WS not to convert the rendered clips (since they were compliant), and used DVD WS to burn the disk.
When I play the burned DVD, the scene freezes for a second or half second at the end of a clip before going into the next clip.
I've noticed this before in DVD WS. Is that just the way it is, or is there a fix?
Thanks,
Alan
Results 1 to 1 of 1
How to fix Cyrilic/Latin letters in Aegisub or Subtitle Workshop?
By NangelK in forum SubtitleReplies: 0Last Post: 23rd Jun 2009, 16:56 -
DVD chapter not right how to fix it?
By warlock110 in forum Newbie / General discussionsReplies: 4Last Post: 19th Feb 2009, 20:36 -
Problem with transitions/chapter marks using Nero 7
By dvdtcb in forum Newbie / General discussionsReplies: 0Last Post: 17th Jan 2009, 11:58 -
Buggy chapter transitions with PgcEdit Play All scheme
By ajrecs in forum Authoring (DVD)Replies: 2Last Post: 11th Oct 2008, 07:00 -
Fix ghost effect in a bad ntsc to pal converted original DVD
By Talayero in forum Video ConversionReplies: 8Last Post: 16th Jul 2007, 05:40
