Hi!
Tried to install the Pinnacle DC10 plus on an MSI KT266 Pro mainboard (1,4GHz Athlon, 512MB DDRAM, Windows 9. I installed the driver and reboot the system. Everything looked fine and I captured a few seconds. During playback the system crashed (black screen). After reboot I got an error message (card failure). I booted again but the DC10+ didn't work. Again I installed the complete system and again the system looked fine after installing the DC10+ driver. This time I didn't captured and shutdown the system. After reboot I got the same error message...
In my old system (Pentium 200MHz, ASUS P55T2P4, 128MB, Windows 9the card still works fine (but slow...).
Anyone an idea?
On the pinnacle support site there is a reg-file which could solve the situation.
File is DC10.reg and is for solving some problems with drivers >900 Mhz
No garanties. Check the info-file.
Another link for the file, besides the pinnacle site, is:
http://www.videotipps-2.purespace.de/berichte/tools/dc10reg.zip
Check:
http://videotipps.purespace.de/download.htm
Also solvations:
800x600 16bit
No DDraw checked
DMA checked for capture drive
disable "write behind caching" under system \ troubleshooting
good luck -
Thanks a lot!
I installed the reg-file and a file called ppe105.exe (both from pinnacle). Now capturing works really fine, only playback via DC10plus' TV-Out makes still trouble. After a few seconds playback Windows crashes completely (black screen). Maybe someone has an idea. -
ppe105.exe is the most actual driver as far as i know. Maybe this is an option?
Playback (i asume/this is the same as Overlay?) also failed when i had the DDraw-box checked. Unchecking did the trick, but then i could not capture in the 768x576 (no crop)resolution. I don't want to capture in that resolution, but it whas something i could not believe it could do on my Athlon 1000, 256Mb, 60Gb-IBM-7200rpm, ViperV777-Ultra 32Mb.
So i tested some other things. The card has some good reading material on this and finaly i did it by altering some video-card registry keys which related DirectDraw & Overlay.
Also check http://videotipps.purespace.de/ for further information about Troubleshooting
Problems with Pinnacle Studio 9 using DC10+ Capture Card
By alexh110 in forum Capturing and VCRReplies: 0Last Post: 29th Jul 2011, 03:03 -
Software for S-video output on Pinnacle DC10 plus card(XP)
By Eightbitgnosis in forum Software PlayingReplies: 2Last Post: 30th Jan 2010, 09:33 -
Miro DC10 /DC10+ and fedora
By bmw524 in forum LinuxReplies: 2Last Post: 14th Nov 2008, 14:54 -
Pinnacle AV/DV2 or DC10+B miserable performance
By cybertheque in forum Capturing and VCRReplies: 1Last Post: 17th Sep 2008, 21:44 -
Pinnacle DC10 Plus on Windows XP
By Paulsa in forum Capturing and VCRReplies: 0Last Post: 3rd Apr 2008, 10:02
