Hi. Firstly, I used to be able to make this program work before, but now it's flatly refusing to. I have v2.0, but all previous versions have the same problem, which is this ...
Open DVD Root ; select movie Title ; opens up window for Input Settings ; then click Ok and it comes up with MS error "DVDx.exe has generated errors and will be closed by Windows. An error log is being created"
I have all things installed including AVISynth, DirectX 8.1 and the CM-Avisynth.prm files. The only time I can get it to go past the Input Setting (sometimes) is when I delete the auth.dll file and the DVD screen comes up, but I am then not allowed to select the Premiere Plugin encoder->Video Server to use the AVISynth outputter for use in TMPGEnc.
Does ANYONE have any idea how on earth I'm meant to use this program (without it crashing)? Do you know why it does crash and what I can do to resolve this problem? Many thanks in advance.
