hi,
ive tried to convert several of my vcd's back to mpegs so that i can put them on dvdr,ive used the guides from this site,my problem is most films i cant do,either vcdgear cant convert to mpeg (common problem is that 100s of mpeg files of the movie are produced each abot 10 seconds long) also if i do get the films to mpeg,joining the 2 files together doesnt work,tmpgenc tools seems to work on the edit but when you check the final file back the join is nowhere near where you set it (ie after about 20mins of the film not 45) is this protection? or am i missing something?
cheers
jonx
p.s virtualdub gives a sync packet error if i try to open the mpegs.
Your going to have a lot of problems trying to join 10 second movie clips. Why not just drop them into the Authoring program one after another, The DVD player will play them all
How can I join MPEG-2 files?
By sofakng in forum EditingReplies: 6Last Post: 30th Jul 2010, 11:20 -
How to join clips in Mpeg Video Wizard? (Thanks)
By seymoria in forum EditingReplies: 5Last Post: 29th Jan 2009, 14:23 -
join mpeg files without re encoding
By akakiami in forum Video ConversionReplies: 5Last Post: 12th Nov 2008, 02:18 -
can't join simillar mpeg-1 files without re-encoding
By sohaibrazzaq in forum EditingReplies: 3Last Post: 26th Jan 2008, 09:09 -
VirtualDub-MPEG Warning Improper Join?
By geewhiz in forum DVD RippingReplies: 2Last Post: 23rd Jun 2007, 08:10
