  1. I use VCDEasy to create (S)VCDs with menus but I can't figure out is it possible (and how) to save current menu settings (like "job" or "project") for later.
    It is pretty annoying to set relations between clips again and again when I want to continue to work on some (S)VCD.
    XML file it cretaes contain every needed information about work but I don't know how to "load" it into VCDEasy - if it is possible at all ...
    Any ideas, tips, hints ?
  2. i havn't found a save option either.
    Its really annoying having to wait while it adds all the stills i've created, (and with 1500 stills it takes a long while!)
  3. VCDEasy doesn't as yet have the ability to LOAD/SAVE projects.
    Good thing it is a work in progress...
    Regards.
    Michael Tam
    w: Morsels of Evidence
