I have burned many SVCD's, and I have never had to use VirtualDub until recently. I had a AVI file that someone had insertted a loop into at the end saying someone was great. When I converted this AVI file to SVCD, it didn't work correctly. Therefore, I used VirtualDub to erase the last few frames that were looping. You can accomplish this by selecting:
Video/Select Range. Just place the ending range to stop before the looping frames or where ever you want it to stop.
However, this process still created a few coasters from my CDR's until I learned the correct settings to use. Under Video and Audio, you need to make sure that Full Processing mode is selecting. You also need to select Video/Compression and select DivX MPGE-4 Video Codec. This worked for me, but there may be other options to use.
Once I did this, I was able to once again create another beautiful SVCD using TMPGEnc.
Regards....
Results 1 to 1 of 1
Settings Xvid codec in Virtualdub
By Docoptik in forum SubtitleReplies: 7Last Post: 6th Mar 2011, 14:15 -
Virtualdub settings to capture DV
By magillagorilla in forum Capturing and VCRReplies: 12Last Post: 11th May 2010, 13:42 -
Help with Best x264 Settings and Virtualdub Avidemux
By ZZen in forum EditingReplies: 13Last Post: 9th Jun 2009, 08:48 -
VirtualDub -> Handbrake m4v, audio settings?
By milltone blabbit in forum AudioReplies: 5Last Post: 30th May 2009, 22:33 -
If VirtualDub capture, which one and what settings?
By tluxon in forum Capturing and VCRReplies: 3Last Post: 20th Jan 2009, 20:05
