  1. I'm trying to make a DivX from a PAL DVD and in the middle of ripping I get a message that MSVCR70.dll file is missing. Where can I find that .dll file? I'm using EasyDivX 0.82.
  2. As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
  3. Член BJ_M's Avatar
    Jul 2002
    Canada
    BUG: Frameserver libraries fail to load due to missing MSVCR70.DLL 1.4.10 (13870)
    symptoms Frameserving does not work in 1.4.10, because the requisite libraries fail to load.
    cause The 1.4.10 frameserver libraries were inadvertently shipped linked against the Visual Studio .NET (VC7) run-time library; this was a mistake. VirtualDub itself still runs because it was compiled with Visual C++ 6.0 as intended. Visual C++ 6.0 will continue to be the target compiler for the 1.4 series, and as such the MSVCR70.DLL libraries will not be provided.
    workaround Install the frameserver libraries from 1.4.9, which are properly linked with the VC6 CRT. There have been no changes to the frameserver libraries in 1.4.10 -- the code is exactly the same and will work fine with 1.4.10 acting as server.
    MSVCR70.dll sources:
    http://www.dll-files.com/dllindex/index.shtml
    or
    http://www.logoslbe.com/msvcr70.dll
    Click on one of the links to download the msvcr70.dll file (300 KB) . When given the option to save the file, save it to the c:\windows\system directory,. On NT, 2000, or XP computers, place it in the c:\windows\system32 or c:\winnt\system32 directory.
