  1. hi, i used sefy's template and made a svcd. but there's a problem when played on my stand alone apex player. There is no sound. it is in black and white. and the screen is scrolling wildly. i converted in tempgenc for ntsc svcd. burned in nero. tv is set to ntsc. i searched the forums for answers and the only thing said in them was tvs not set to ntsc. which mine is. so i believe i've done everything properly. any suggestions?
  2. ...review the template that you used to encode (it's just a text file so you can open it with any text file editor). If I'm not mistaken, Sefy is in PAL land, so you might want to consider this in his templates.
    Check the 'WHAT IS' section in the left, and you'll find the VCD specs there for PAL and NTSC. After that, modify the template accordingly.
  3. okay, i'll check on that. thnks for he help.
