what a subject
is there any way to seperate an avi into video and sound without the need to reencode the video?
my problem is that i want to convert my nge-videos (if u don't know what that is, it doesn't matter) in svcd using dvd2svcd and cce.
the problem is that some avis have a divx audio stream which dvd2svcd can't handle.
reencoding the audio is no problem, but i have to get that audio off the avi
thx for ya help
"It's better to burn out than to fade away! Peace, Love, Empathy."
Kurt Cobain -
two choices:
1. select 'video only' and encode from the avi but don't use the audio (I assume CCE has the same capability as TMPGenc). Then remux with the encoded audio.
2. use virtualdub to save the audio as a wav file, then save the video as an avi with sound disabled. Process however you want.
Can I change the pixel aspect ratio in an x264 AVI without reencoding?
By Calidore in forum Video ConversionReplies: 24Last Post: 16th May 2018, 17:24 -
Need to convert h264 avi to mp4 without reencoding, help?
By chupacabra24 in forum Video ConversionReplies: 2Last Post: 30th Oct 2011, 12:02 -
how to change aspect ratio (PAR) in AVI without reencoding
By deejay.2001 in forum Video ConversionReplies: 1Last Post: 25th Sep 2010, 10:33 -
Add a watermark to .avi x Reencoding
By dexter30 in forum EditingReplies: 21Last Post: 8th Sep 2009, 21:42 -
Delete Sound/Crop Video
By OG24 in forum Newbie / General discussionsReplies: 11Last Post: 9th Aug 2007, 15:59
