hey all whats the difference in capturing to avi then converting to mpeg 1 at 1500 cbr than just capturing directly to mpeg1 1500 cbr ? would the quality be that much bettter capturing first to avi? thanks
I feel that capturing straight to mpeg will give you the best quality of the two. Every time you encode you will lose a little quality.
Hello. -
Naturally, this is a very subjective subject. Again, it depends on the software used. PowerVCR II and ATI MMC 7.7.0.1 are my "real-time" options I have tested. PVCR 1500 CBR compared to TMPGenc... Forget about it. TMPGenc wins out. MMC vs. Tmpgenc - VERY CLOSE, though TMPGenc wins out.
Neither of the real-time capture applications I have give you enough control over the encoding process (whether CBR or VBR [only in the latter]) to give you the power of the offline encoders. This said, 90% of my daily recordings use MMC direct to MPEG. The other 10% I use VDUB and Huffy, as they are my precious Hi-8 videos that I want to archive perminantly.
If you watch your videos on a 5" - 19" TV, the method of encoding will be much less important to you. I have a big screen, so the quality of encoding is paramount on something I will be watching more than once.
TJD
Please Help with converting AC3 in an AVI to an AVI with MPEG-1/MPEG-2
By twin1701 in forum Newbie / General discussionsReplies: 4Last Post: 13th Jul 2010, 15:11 -
new Virtualdub MPEG - still a colorspace problem with MPEG-&
By sanlyn in forum EditingReplies: 6Last Post: 10th Aug 2009, 23:18 -
How to convert an MPEG file to DV-AVI Type 2 using MPEG Streamclip
By MAdNEZ in forum Newbie / General discussionsReplies: 15Last Post: 4th Aug 2009, 08:30 -
Strange problem between AVI(mpeg) file and DVD based on AVI(mpeg) file
By 1234567 in forum DVD RippingReplies: 49Last Post: 15th Feb 2009, 08:36 -
DGIndexed MPEG or AVI wrapped MPEG best for AVISynth?
By flywitness in forum EditingReplies: 1Last Post: 12th Sep 2008, 10:08
