I am wondering if there is a way to work out how to fit a movie (namely DivX) onto X number of cd's accurately in VCD format.![]()
Secondly Im planning on making VCD's from anime episodes, and want to find out how to make each episode selectable via the Skip button. I think this means I want to make 'chapters?' from each episode.
thanks for Your help![]()
Results 1 to 11 of 11
The Hellsing family will purify this world...
problem is that I want to make VCD's and they seem to be for SVCD's
anyone have anymore information please
The Hellsing family will purify this world... -
it's even easier for VCD'sOriginally Posted by TheLostTimberwolf
80 minutes of standard VCD will fit on an 80 minute CD
that's all there is to it...but that holds true only if it is standardwhat are you askin' me for...
I'm an idiot! -
As I recall, Divx is an AVI format. So you will have to convert to MPEG-1 to install it on a VCD, correct?
Hello. -
ok , what does Standard mean exactly?
and yes the problem is that when i split the divx into 2 i dont know how big to make them so that they fit onto 2 cd's accuratelyThe Hellsing family will purify this world... -
VCD Standard is 352x240/288 CBR 1150Kb/s
www.vcdhelp.com/vdc.htmMay the force be with you. -
convert the divx to VCD first, and split that to the right size...that will be easierOriginally Posted by TheLostTimberwolfwhat are you askin' me for...
I'm an idiot! -
Cheers for all the help
thanks
sorry I took a while to reply, been sick for a few days , wasnt fun
PowerDirector makes final DVD files, size larger than mpg file's size, why?
By Xor2 in forum Authoring (DVD)Replies: 4Last Post: 22nd Dec 2011, 18:29 -
File size differs from data size--HUH?!
By atoledo123 in forum MacReplies: 2Last Post: 9th Sep 2011, 14:19 -
Font size will not change size
By pgwillin in forum ffmpegX general discussionReplies: 9Last Post: 8th Jan 2011, 15:04 -
How to fit the large size picture to the smaller size for print?
By coody in forum ComputerReplies: 7Last Post: 1st Apr 2009, 09:46 -
small video size, but showing incorrect size (too big)
By mandy in forum Newbie / General discussionsReplies: 1Last Post: 17th Mar 2009, 05:14
