Hey guys..
im wondering if its possible to convert a Widescreen Movie to Fullscreen?
Thanks!
Use TMPGEnc to encode the MPEG for you.
After you load the Audio and Video Files and Select the Template, click the Settings button and go to the Advanced tab.
Set all the properties of your sorce video and then you will see a box (can't rember what it's called) with the setting in it "Full Screen - Keep Aspect Ratio" or somthing like that, change it to "Full Screen (No Margin)" (I think thats the right one. and you will end up with a 4:3 version of the Video.
Just try it out with preview first to make sure i got it right (under the FILE menu).
Fingers crossed it should work, but i've never done it before =DVD to VCD made eazy
http://www.eazyvcd.tk
Dvd player plays widescreen dvds in fullscreen on widescreen tv
By Fireworks_at_Dawn in forum Newbie / General discussionsReplies: 35Last Post: 24th Sep 2012, 08:24 -
Widescreen shows up on the PC but as fullscreen on the TV?
By Moontrash in forum Authoring (DVD)Replies: 8Last Post: 17th May 2010, 17:26 -
Fullscreen vs. Widescreen: why still airing new content in fullscreen ?
By vhelp in forum DVB / IPTVReplies: 56Last Post: 2nd Oct 2009, 14:54 -
Widescreen to fullscreen conversion
By F8L23 in forum Video ConversionReplies: 15Last Post: 13th Dec 2008, 12:38 -
Widescreen To Fullscreen
By OG24 in forum Newbie / General discussionsReplies: 10Last Post: 11th Aug 2007, 15:51
