Anyone know if its possible to capture directly to SVCD using the AverStereo Card?
When I try to use VirtualDub to capture, the max. vertical resolution is 240.
I can capture at 720x480 using the included software, but there is no SVCD 480x480 setting with the packaged software.
Does anyone know of software that will capture to SVCD (ideally directly) using this capture card?
I am not completely opposed to reencoding, but I'd appreciate any tips for quick transfer of analog video(TV Shows and VHS Tapes mostly) specifically to SVCD. I like SVCDs for thier quality, but I'm starting to wonder if VCDs arent just as suitable for analog captures.
System Specs:
Celeron 1.2gig
512mb RAM
40mb 7200rpm HD + video dedicated 80mb 7200rpm HD
DVWonder Firewire card
AverStereo TV Card
Results 1 to 1 of 1
Internal Capture Card? Possible to Capture direct to PC?
By Ryutso in forum Capturing and VCRReplies: 11Last Post: 25th Jul 2010, 16:58 -
Can someone direct me to a good capture device..
By KameronK in forum Capturing and VCRReplies: 5Last Post: 28th Mar 2008, 22:46 -
DV Direct to DVD (DV Capture)
By coisty1856 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 13th Sep 2007, 15:15 -
Capture / Burn direct to drive
By Bob08 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 19th Jul 2007, 16:28 -
Direct capture from the PC DVD player?
By hitman3000 in forum Authoring (DVD)Replies: 1Last Post: 2nd Jul 2007, 18:37
