the burn did not work so here is the log maybe you can help
[Internal Xml Generation]
Internally computed XML generated successfully as "C:\Program Files\VCDEasy\videocd.xml"
[VCDxBuild.exe]
GNU VCDImager 0.7.12
initializing libvcd 0.7.12 [cygwin/i686]
this is the UNSTABLE development branch!
use only if you know what you are doing
see http://www.hvrlab.org/~hvr/vcdimager/ for more information
changed volume number to 1
changed volume count to 1
changed restriction number to 0
changing 'next volume use sequence 2' to 0
changing 'next volume use lid 2' to 0
changed volume label to `VIDEOCD'
changed publisher id to `VCDEASY_V111'
changed application id to `CDI/CDI_VCD.APP;1'
changing 'relaxed aps' to 0
adding pbc (Selection-000/2)
adding pbc (Selection-end/3)
sequence count 1
adding sequence #0, C:\My Downloads\Half Baked (VOA) (DIVX).mpg
strange (possibly non-compliant) user_data seen... (not a problem, usually a sign of TMPGEnc)
APS' pts seems out of order (actual pts 939.678467, last seen pts 939.711833) -- ignoring this aps
APS' pts seems out of order (actual pts 1857.528733, last seen pts 1857.562100) -- ignoring this aps
APS' pts seems out of order (actual pts 2216.187033, last seen pts 2216.220400) -- ignoring this aps
APS' pts seems out of order (actual pts 2474.778711, last seen pts 2474.812078) -- ignoring this aps
APS' pts seems out of order (actual pts 2506.110011, last seen pts 2506.143378) -- ignoring this aps
APS' pts seems out of order (actual pts 2612.516311, last seen pts 2612.549678) -- ignoring this aps
APS' pts seems out of order (actual pts 2690.794511, last seen pts 2690.827878) -- ignoring this aps
APS' pts seems out of order (actual pts 2808.545478, last seen pts 2808.578844) -- ignoring this aps
APS' pts seems out of order (actual pts 3879.815678, last seen pts 3879.849044) -- ignoring this aps
APS' pts seems out of order (actual pts 4422.791444, last seen pts 4422.824811) -- ignoring this aps
APS' pts seems out of order (actual pts 4529.097644, last seen pts 4529.131011) -- ignoring this aps
pts start offset 0.340078 (max pts = 4791.326278)
playing time 4790.986200
scanning mpeg sequence item #0 for scanpoints...
already scanned... not rescanning
pbc: psd size 32 (extended psd 56)
iso9660: highest alloced sector is 257 (using 300 as isosize)
generated image (360018 sectors [80:00.18]) may not fit on 74min CDRs (333000 sectors)
writing track 1 (ISO9660)...
writing track 2, MPEG1, NTSC SIF (352x240/30fps), audio[0]: l2/44.1kHz/224kbps/stereo ...
MPEG packet statistics: 299962 video, 58865 audio, 0 zero, 0 ogt, 516 unknown
writting post-gap ('leadout pregap')...
finished ok, image created with 360018 sectors [80:00.18]
[CDRDAO Disk Info]
Cdrdao version 1.1.5
0,1,0: ATAPI CD-R/RW 24X10 Rev: P.HJ
ERROR: No driver found for 'ATAPI CD-R/RW 24X10' (Try to use "Force Driver" in the "CDRDAO settings" page, with 'generic-mmc' for example)
ERROR: Cannot setup device 0,1,0.
Firstly, you probably need to install/update your ASPI layer. The solution that seems to work the best is to get ForceASPI for http://www.doom9.org
Regards.Michael Tam
w: Morsels of Evidence
Can not log onto PC
By Noahtuck in forum ComputerReplies: 19Last Post: 12th Dec 2009, 22:35 -
Log in?
By alintatoc in forum ComputerReplies: 10Last Post: 5th May 2009, 02:04 -
Log Me In
By Lucifers_Ghost in forum ComputerReplies: 3Last Post: 6th Jun 2008, 08:02 -
Log in
By MintyJ in forum ffmpegX general discussionReplies: 3Last Post: 15th Mar 2008, 18:18 -
[Help - Log inside] Having issues burning on Dell M1330 with Vista using
By dellfanboy in forum Newbie / General discussionsReplies: 2Last Post: 23rd Feb 2008, 21:14
