I have heard conflicting reports: is it necessary to put the VIDEO_TS folder in uppercase letters? What happens if it is in lowercase? Does it make it unreadable? Are players that finicky?
Bruce Skousen
multi-posting pisses off the moderators, I know - I did it a couple of times and had my topics closed.
Andy
Yes I know. I inadvertantly added the post in the DVD writer section by mistake. BTW, you didn't answer the question.
Bruce Skousen -
Although I always use U/case VIDEO and AUDIO_TS when authoring, I have come across several commercial DVDs with just "Video_ts" in the root.
These DVDs played OK regardless on my equipment.
For compatibility with all players, it doesn't hurt to u/case and add both VIDEO and AUDIO titleset names. -
The original DVD spec required all capitalization. This hasn't changed. However, some players are accepting Joilet nameing extentions (ie, lower case lettering). For full compatibility, always use caps... always.
This could be something that Windows did (you have to check a box to get it to display a file as it was written). I doubt that any commercial DVD would stray from the standard like this.I have come across several commercial DVDs with just "Video_ts" in the root. -
indeed, most players go beyond the standard and will accept variations in case. The good authoring programs ive used and ifoedit all insist directories AND filenames are all uppercase so best to do this
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 02:52 -
WMV files: Changing "Recorded Date", "Media Created" fields in metadata
By axhack in forum EditingReplies: 5Last Post: 18th Sep 2010, 02:27 -
imgburn VIDEO_TS successful but "No Disc"
By djstatusent in forum Authoring (DVD)Replies: 9Last Post: 28th Nov 2009, 11:35 -
Make menu for "VIDEO_TS" folder (files inside it)...
By Chana1 in forum Authoring (DVD)Replies: 18Last Post: 24th Jul 2007, 09:29 -
Trying to get a video_ts file, but getting ".avi.ff.mpg"…
By whoracle in forum ffmpegX general discussionReplies: 6Last Post: 22nd Jul 2007, 23:14
