I've noticed that VOB file size does not seem to be related to bitrate. Generally a VOB file of 1GB holds about 25 minutes of video. What puzzles me is the bitrate,most movies are at 9800bit but I see some things like TV episodes that are only 6000bit but use the same size file,that is 25 minutes equals 1GB??? Does this lower bitrate effect encoding to SVCD in Tmpeg?
The only dvds that use 9.8mbits are superbit dvds. All other commercial dvds typically use avg bitrates between 5 and 6mbits. How were you determining that the bitrates of these dvds were 9.8mbits? Were you looking at the nominal bitrate in the bitrate viewer? You need to actually look a the calculated avg.
Remember that dvds typically have several Ac3 streams and also the multiplexing overhead is probably significantly larger than that of vcds and svcd. If you take these factors into account, however, than you'll see that the bitrate and the filesize match up correctly.
Bitrate/QC same file size, is quality the same?
By marioval in forum DVD RippingReplies: 1Last Post: 4th Nov 2010, 08:56 -
Does half d1 alter file size at all or is it just how the bitrate is used?
By yoda313 in forum Video ConversionReplies: 14Last Post: 17th Oct 2010, 19:28 -
Xvid bitrate and file size problem - Heeelp!
By Salinas in forum DVD RippingReplies: 0Last Post: 10th Mar 2010, 17:05 -
File Size & Video Bitrate Calculator
By wiseant in forum Video ConversionReplies: 3Last Post: 27th Nov 2009, 21:59 -
Problem with bitrate and file size when encoding with XviD
By megakoolkid in forum Video ConversionReplies: 13Last Post: 25th Jun 2007, 17:12
