Hello! Is there any program or plugin (for Premiere, VirtualDub, ....) that can get for example each 14th frame and hold it for ~1second? Thank You!
It can be done with Avisynth, theoretically. You can freeze a frame for some time. But to freeze every 14th frame for 1 second? Apparently, you are trying to create some special effect. If the clip is not too long, it's doable with Avisynth and not too difficult.
It is record from security cam and it writes from each cam one frame (cam.1-frame.1;cam.2-frame.2;....;cam.n...frame.n;cam1-frame.n+1;...) but thanks!I already did it using changing Frame rate in VirtualDub.
Thanks for everyone!
Avidemux: The beginning frame is not a key frame. Please move the A marker
By devilcoelhodog in forum EditingReplies: 13Last Post: 8th Jun 2015, 12:38 -
How do I debug/extract i-frame p-frame and b-frame?
By jwbrasil2 in forum ProgrammingReplies: 0Last Post: 20th Nov 2011, 12:24 -
Play an MTS file frame by frame, displaying timecode or frame number
By SeánB in forum Software PlayingReplies: 5Last Post: 5th Oct 2010, 16:26 -
WMP and VB6, is it possible to step forward or back frame by frame?
By gadgetguy in forum ProgrammingReplies: 11Last Post: 6th Mar 2009, 20:00 -
Advancing/Rewinding Clip Frame by Frame on Windows Movie Maker (Vista)
By ione in forum EditingReplies: 20Last Post: 9th Sep 2008, 22:53
