  1. where can i find the above software? and am i correct in thinking that if the original is less than 4.3 gig it will be an xact copy quality wise as the original?
    ps im after the english version, im running win98
    cheers
  2. johnno,
    I am not positive but I do not think their is a DVD2DVDR program....I believe it is just a process. Which is just a way to fit >4.3 GB movies onto 1 DVD-R.
    And yes, you are correct, if the DVD is less than 4.3 GB you can make and exact copy, just like a CD.
    If you do find that DVD2DVDR is a program repost and let me know
    Nov 2001
    Malaysia
    Have any of you guys used this software, i can;t seem to load it. I think it;s becoz i'm using win98 and not XP. Also if you've tried it, please help me out and lemme know whether it can convert DVD9 to DVD5 with menus and extras automatically. Thanks.
    Jul 2002
    BATON ROUGE, LA - U.S.A.
    i think its a trojan
    Where I walk, I walk alone. Where I fight, I fight alone.
  5. downloaded but no luck, its wont work on my systen running win 98
