I have some movies which is like 710mb, means i can't burn them, so i was wondering which program is the best to edit it without changing the quality. I want to cut beginning credits and end credits so i can reduce size to 700mb and i don't want quality to change, or maybe just very very little.
Thanks.
Ok, i cut all i needed but when i save it with "Save as AVI" it sais that file will be very large, and file is like 65GB. How do i save to keep same size ratio?
Nevermind i found that COMPRESSION option hope i'll figure it out by myself, sorry i'm newbie to all that stuff.
You can also try setting the video and audio to "direct stream copy" so it won't re-encode (the first step in the above referenced link to the vdub guide...).Originally Posted by torettoAs Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
Yeah that's what i did and its converted it just the way i wanted and alot faster.
AVCHD Editting Premiere CS4
By AntAskew in forum EditingReplies: 7Last Post: 13th Jan 2011, 07:12 -
I have editting questions
By wolfspirit1964 in forum Newbie / General discussionsReplies: 12Last Post: 16th Feb 2010, 22:15 -
PC for HD editting
By Olivier_14 in forum ComputerReplies: 4Last Post: 26th Feb 2008, 14:02 -
Any video editting expert?
By cpt.iove in forum Newbie / General discussionsReplies: 8Last Post: 15th Feb 2008, 18:35 -
Many problems with editting video project.
By bluestar88 in forum EditingReplies: 0Last Post: 3rd Jun 2007, 18:47
