hi - has anybody used any of the usb capture devices? how is the quality?
Results 1 to 10 of 10
Hi, I have a Dazzle DVD Creation Station 200 and it is ok. You must capture to dvd or else it won't look very good. When capturing the preview looks horrible. Then after you convert it it looks ok. Then after you burn it to dvd it looks great. Has its share of bugs though. If you have anymore questions email me.
Hey Mxjshaf69,
Have you had any audio sync problems cause I had it before but returned it because of money issues, I would capture dvd and then through DVD Complete software when it would separate the audio and video to make the project and then put it back together I would preview it but audio would not be in sync, have you had this experience yet? if so what did you do to correct it because I'm thinkin about getting it again -
I use the Hauppauge WIN TV PVR(USB) on W2K, Dell Latitude. I am very pleased with the quality of the captures (there are several levels of quality). I have captured up to a 4 gig movie.
Any specific questions I will be glad to answer. -
oh....also, do you get any audio sync problems with regards to the wintv? you mentioned different video quality, can you clarify? thanks.
Yes, but i fixed it. After capturing you have to convert it with TMPGenc in parts. Convert 1/4 of it at a time and then merge them together and you will have a perfect video.Originally Posted by lrosado
i just bought a Dazzle DVD Creation Station 200 from best buy yesterday..... is there any problems with it..... i bought it so i can cature video using my laptop...... i though dazzle was one of the best capture devices out there??????
There is software on the Hauppauge Web page for Windows XP.
The different quality levels start at mpeg1 (VCD) and go to mpeg2.
The higher the quality the higher the bits per second.
I have had audio sync problems, using the VCDConvert program solves them. Also it appears that some DVD players are more sensitive then others. I have had no sync problems playing back on my DELL Latitude DVD. But I do get sync problems on my Apex. Let me add that I am very pleased with the quality of the WIN TV PVR. I have had no Software problems.
Reliable USB capture devices?
By slats7 in forum Capturing and VCRReplies: 21Last Post: 11th Mar 2012, 20:32 -
PowerDirector 8 doesn't work with USB capture devices
By chris18 in forum Capturing and VCRReplies: 0Last Post: 10th Feb 2010, 07:28 -
USB capture devices vs USB tuner devices...... which are better for recording?
By True Colors in forum Video Streaming DownloadingReplies: 1Last Post: 31st Jan 2010, 16:04 -
Are there any devices that can capture 480p with component through USB or P
By Cyber Akuma in forum Capturing and VCRReplies: 7Last Post: 2nd Aug 2009, 03:29 -
PCI and USB capture devices to AVOID? Go straight to WME...
By tedbragg in forum Capturing and VCRReplies: 0Last Post: 29th Feb 2008, 11:02
