I am started to make a vcd... i did this as you VCDHELP.COM described it at www.vcdhelp.com/divxtovcd.hm ..... But now that i made it i wanted to test it on my Cd-i player to watch in on television.... but he couldn't read the cd... i read somewhere some stuff about some sort of green book and white book... and Digital Video or something, but i really don't know now how to make a cd work on my cd-i! Please Help me!!!
thanks in advance
why doesn't anyone reply??? i need an answer!!!!
Minimi,
To help you i need to ask this question:
Does your CD-i player have a digitalvideo cartridge installed, this is
required for the CD-i player to play VCD's.
vcd4ever. -
yes it is installed.... i also watched some digital cd's like Top Gun Bio Force and Playing Dangerous....and Mortal kombat... they where bought in shop
If you use an authoring program like Nero or VCDeasy you have to select the CD-i compliant checkbox to add some files the CD-i player needs.
What program do you use to burn?Panasonic DMR-ES45VS, keep those discs a burnin' -
Minimi,
Have you used a vcd template when encoding the mpeg, and have you
included the cdi-app.
It just hit me, i hope you haven't burned it on a cd-rw...if you have
try it on a cd-r.
vcd4ever. -
Minimi,
I have a Philips CD-i 450 player, what player do you have.
vcd4ever. -
I had the cdi-370! the nice one with the tft screen... it play all that was thrown at it... well apart from cdrw... best disks were Ritek ones though they played without resetting the machine!
Kev!
Tmpeg tempalte for VCD (ntsc or pal)
nero 5 for burning & awaya we go
Nice player the 370 was.. no cartridge needed just the software
(shame its dead)
Kev!
