The jumping is like during movements which is easier to see. Like when someone is walking you can like see the frame jump or something. I want to beable to fix this. This happens when i covert a .avi to a mpeg2 with tmpgenc.
Any help appreicated
Are the frame rates the same in the .avi and your mpeg files?
If they are different, try re-encoding with the same frame rate as the avi file. -
The avi file is 25 fps what template should i use in Tmpgenc to beable to play on my dvd player ? I am in the US BTW. I am using NTSC Film template right now in tmpgenc so figuring that could be wrong sense it says 29. something fps. I want my stand alone dvd player to play it and my computer.
try changing the field order and re-encode. (especially if this only occurs during movement)
cheers -
If the avi is encoded at 25fps, thats the Pal framerate. As you are in the US you need to encode to NTSC or NTSC film. There is a guide on doing this under Howto Convert, left of this page.
Sony HDR-SR7 recorded video jumping around...
By MikeZZZZ in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 54Last Post: 11th Feb 2017, 03:23 -
jumping video
By natty in forum Newbie / General discussionsReplies: 8Last Post: 2nd May 2011, 11:27 -
Help: Video jumping/flickering when edited
By toyota200x in forum EditingReplies: 15Last Post: 8th Nov 2010, 07:22 -
EasyCAP w/ Ulead and Pinnacle - Video Stuttering/Jumping/Lagging problem
By Logan289 in forum Capturing and VCRReplies: 0Last Post: 30th May 2010, 14:25 -
Jumping, Stuttering Video
By Smack2k in forum Video Streaming DownloadingReplies: 7Last Post: 6th Jul 2009, 19:36
