Hi,
This is a follow up to a previous question.
Based on the advice of anothher forum user, I have decided to get a Messiah modchip for my PS2.
I have never soldered anything and I don't intend to start now. Is there anyone, or a company, that sells pre modded PS2s?
I found a couple of companies on the net, but they are sellin PAL PS2s.
Thanks,
dafoe
try console source www.consolesource.com or www.modchip.com I haven't really found a modchip that does it all without the use of a gameshark but if you do find something let me know
don't hang your dirty laundry in public -
Actually, the Messiah and Magic 2 chips claim to direct boot everything including PS 1 & 2 backups on CDR and DVDR as well as originals without the need for a Gameshark.
As long as you don't mind soldering or the $80-$100 pricetag, that's the way to go. I'm going to buy a Messiah. I'll worry about getting installe later. -
I"m pretty sure you can get the messiah pre-modded system on www.modchip.com I also know www.consolesource.com has premodded ps2 system's for sale but like i said i'm still leary about spending 2-3 hundred dollers on a chip or premodded system that could possibly not work or for that matter only work with a game shark i've talked to a few people from around here who put the chips in ps1 and 2's and they say the chips available now say they do the job but in actualality they still need the gameshark to boot ps1 backups. Now they could be bullshi**ing me. But who know's i'm not buying anything till i know someone that has bought one and it worked. That's just me i'm a cheap bastard!!
http://www.modchipspot.com/ps2modifiedsystem.htm
http://us.hackershardware.com/catalog/playstation/index.php
here's a couple i found right off hand take a look...i looked personally to make sure there where actually modified systems on here and there is have fundon't hang your dirty laundry in public
Easycap 2.0 Installation.
By xAnonymousx in forum Capturing and VCRReplies: 2Last Post: 7th Jun 2010, 07:37 -
PS2 Mod Chipping...
By SE14man in forum Newbie / General discussionsReplies: 10Last Post: 20th Jan 2008, 15:38 -
Installation error -
By ruggerjvd in forum ffmpegX general discussionReplies: 4Last Post: 12th Nov 2007, 09:06 -
No TV picture after new XP installation
By hwendorf in forum DVB / IPTVReplies: 6Last Post: 27th Jul 2007, 11:00 -
installation problem
By gokes in forum ffmpegX general discussionReplies: 1Last Post: 10th Jun 2007, 03:55
