i just want to know what is the simplest conversion program for vcd's? i don't want to get all technical in the process, but just want to be able to press a couple of buttons and wahhla!! so can anyone tell me if there is any conversion program out there like that? where it is as simple as converting a audio track to a wav file? that's what i'm looking for. any help would be greatly appreciated thanks....peace..![]()
Start reading:
http://www.vcdhelp.com/newbie.htmAs Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
Advice for simple, free video-editing software for a newbie
By belltown in forum Newbie / General discussionsReplies: 3Last Post: 4th Sep 2011, 23:25 -
Direct TV/HDTV Signal Question
By RKelly in forum DVB / IPTVReplies: 5Last Post: 12th Mar 2010, 01:55 -
Question about difference between direct capture and sound card recording
By jimdagys in forum AudioReplies: 3Last Post: 16th Sep 2009, 10:09 -
Direct Cable Or Digital Converter Box, quality question
By allthumbs in forum Capturing and VCRReplies: 20Last Post: 3rd May 2009, 21:55 -
direct Tv question and tv tuner
By mohz in forum DVB / IPTVReplies: 3Last Post: 6th Jan 2008, 21:35
