OK. I think I followed the instructions on how to get the motion menu from dvd workshop. The file created is an elementary vid, so i assume i need to add audio to the file, therefore, i bbmpeg the file with audio and now vcdeasy accepts the motion menu vid. This is where i am lost. Do i need to create chapters in order to use motion menu??
I am not sure about the previous, next, return, default fields. Should I set it like this: (example two clips and mmenu)
1st play item: vid1
previous: mmenu
next: vid2
return: mmenu??
default: vid1??
Does this look right?? What does return and default fields do??
TIA
Just my two cents:
Return corresponds to the Return button in the remote control of your DVD player (if you have one), Default corresponds to enter or play button.
In my DVD player, SVCD authored with VCDEASY with menus and chapters, is responsive to return button, but unresponsive to Default button, which is good enough for me. You better test your DVD player to see if it is responsive to return and default.
Main menu/chapters/audio etc all on one motion menu in Encore. Possible?
By Killer3737 in forum Authoring (Blu-ray)Replies: 10Last Post: 11th Feb 2012, 14:08 -
Motion Menu Buttons
By lapetite_66 in forum Authoring (DVD)Replies: 5Last Post: 29th Jul 2009, 16:45 -
Problems when creating a mix with motion menu and static menu
By ihmcjacky in forum Authoring (DVD)Replies: 59Last Post: 15th May 2008, 12:01 -
GFD motion menu stuttering
By spamiaint in forum Authoring (DVD)Replies: 2Last Post: 15th May 2008, 10:58 -
Problem with creaing Menu in VCDEasy
By haris in forum Authoring (VCD/SVCD)Replies: 5Last Post: 16th Mar 2008, 09:17
