Just got this new computer with it on it. It seems to be some kind of authoring program. Anyone know if it's anygood?
Yes, I like it. It also puts a PC DVD player on your home made VCDs. However, do not, I repeat, do not download WinDVD on your new system. The player on your disks will not work on your system once your demo version of WinDVD expires.
Hello. -
I'm trying to use this to burn my re-encoded movies to DVD, but for some reason, every time I open a file with it, it re-encodes them back to the larger file size! Something about not being a "legal" file. Got any sugestions?
How did you encode them once you ripped them from your DVD?
Hello. -
I used smartripper to rip the entire movie, used IFOEdit to strip everything possible(except 1 video and audio), then ran the new VIDEO_TS folder thru DVD2AVI to set up for TMPGEnc. Then encoded at a lower bit-rate to end-up with a .mpg file. Opened the new "smaller" file with My DVD, and somehow it grows a whole Gig back to the "pre-encoded" VIDEO_TS size! Can you believe it!! After all that work!
I was reading in the Help section and it said that any file would be "re-encoded" back to the original size if My DVD considers it to be an "ilegal" file for DVD. I guess some encoders don't make legal files? Or am I doing the encoding wrong? -
I had it and it did not work for me.
Kept getting an out of sync problwm with the video and audio.
Good luck. -
Mydvd is alright, but like many cheaper authoring programs it doesnt fully support 16:9 pal (US?) and iirc it doesnt support 5.1 sound, only 2 channel AC3 and the normal various wav and mp formats
"Live" picture effect - pictures end up "filmized"
By ANOther1676 in forum Software PlayingReplies: 10Last Post: 14th Oct 2011, 12:59 -
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 02:52 -
WMV files: Changing "Recorded Date", "Media Created" fields in metadata
By axhack in forum EditingReplies: 5Last Post: 18th Sep 2010, 02:27 -
"stretching" or "cramming" aspect ratio when I convert .avi to MP4
By Agent Bauer in forum ffmpegX general discussionReplies: 3Last Post: 21st Mar 2010, 11:30 -
Review "HYFAI" MP3/MP4 "Nano" clone from ebay
By NG in forum Portable VideoReplies: 29Last Post: 18th Sep 2007, 06:45
