i've searched around here, and i'm relatively new to this, but i can't seem to figure this out. can a pal dvd be ripped and converted to a vcd or svcd that will play on most ntsc players? is there an easy way to do this? my player seems to play pal vcd's fine, so i know i could easily convert to pal vcd, but i'm interested in something compatible for most dvd players in the US. also, can most ntsc dvd players that play vcds play them in pal format too? any help would be much appreciated.
thanks
Yes a PAL DVD could be ripped and converted to NTSC
Smartripper
DvdX PAL in > NTSC VCD (mpeg 1) Out
Most modern DVD players will play both, sometimes you get PAL in PAL out, so your TV needs to display the correct format also, most modern TV's should....
Some DVD players have NTSC in PAL out and PAL 50 in NTSC 60 out
there are lots of different combinations available.
You need to experiment to see what's best for you, especially with the frame rate conversion, on fast moving movies, it may be a bit jerky
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 13:57 -
PAL VCD -> Proper NTSC DVD w/o Re-Encoding?
By SanctimoniousApe in forum Video ConversionReplies: 8Last Post: 4th Apr 2009, 18:59 -
Video is Jerky after NTSC DVD to PAL VCD Conversion.
By milindb1 in forum Video ConversionReplies: 14Last Post: 10th Sep 2008, 03:22 -
PAL VCD -> NTSC Video for NTSC DVD Authoring!!
By Mickey79 in forum Video ConversionReplies: 5Last Post: 12th Aug 2008, 12:30 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 02:36
