i'm transcoding vob's (4 episodes within 7 vobs) with cce and i'm trying to get it to fit on one dvdr...around 4 gigs even as i want to include the extras...right now the 7 vobs are at 6.58 gigs..my ac3 file is 557 mb..my settings for cce are multipass vbr..4500 average, 2000 min, and 8000 max...will these settings make it fit?
Basicly to figure this out use any of the bitrate calculators, but rember that we need to know how much TIME the video take to determine average bitrate.
could reply chran, couldnt have put it better myself, i wish more ppl knew how to use the advanced features cce has to offer
Time being no concern would you say doing advanced works better than using multipass with 3-5 passes? I do most of my encoding overnight and this would complicate my setup, but I'm a quality junky so I'de do it for most things.
yes using the advance feture you can adjust the bitrate local, and still do a multi pass 3-5 times
ChRaN :-)
Converting Dvds, Settings with bitrate
By Ekeus in forum Video ConversionReplies: 24Last Post: 22nd Mar 2010, 18:19 -
DV AVI -> H 264 (bitrate and other settings)
By xprezons in forum DVD RippingReplies: 13Last Post: 31st Aug 2009, 02:13 -
Question re settings in CCE Basic
By eclipse95 in forum Video ConversionReplies: 4Last Post: 6th May 2009, 16:17 -
Video Bitrate Settings
By bdr13278 in forum Authoring (DVD)Replies: 2Last Post: 4th Nov 2008, 12:34 -
cce video bitrate problem
By DSLGuy in forum Video ConversionReplies: 11Last Post: 16th Feb 2008, 12:53
