I tried the links in the tools area and neither Ifoedit or ReMPEG2 will let me download them? Does anyone know where I can get these files from?
Really need to get them , Please help!
Thanks![]()
Results 1 to 10 of 10
Where I walk, I walk alone. Where I fight, I fight alone.
I Tried those sites and it says unautherized to download? Why does keep this comming up? Try it and see if it works for you.
This is what I get when going there?
Unauthorized download
We're sorry, but this downlod request cannot be authorized. There could be several reasons for this:
1) You clicked on a link on a site that is not part of the Doom9 domains. In this case the URL in your browser would not contain doom9.org or doom9.net. We do not allow that kind of external hotlinking. This site creates a great deal of traffic and it's hard to find a good hosting. We will not provide the bandwith for other sites, too so that they can have a great software archive without having to host and pay for it. Please visit Doom9.org and you can download all the files you want.
2) You're using a download manager. Download managers usually offer to search for alternative download locations. While this is nice for the user, it's bad for the webmaster because it could be that a download which originated on another site could theoretically still be downloaded from this site, without anybody knowing. But there's a solution to this problem:
Set up your download manager to send a HTTP referer, and when you click on a link on the Doom9 site the download will be authorized. Here's how you can do this in Getright:
Go to Getright Configuration, under Advanced/Protocol check Send "Referer" in HTTP Request and then select Generated from the download URL.
The setup should be similar for other download managers.
3) Your browser did not send a referer. This normally happens if you right click on a link and select save-as, or if you copy and paste a link into a new browser window and press Enter. It may also be that your browser is set up to not send any referer, though I did not find any such option in the browser I'm using (IE6). Unfortunately we must test for empty referer or we still have the download manager problem mentioned in 2). But left clicking on a link works just fine and has been tested in IE6, Netscape 6, Opera6 and Mozilla 1.0.
Some software firewalls, for instance the Norton Personal Firewall remove the referer from HTTP requests which will block any downloads on any site that does a referer check. Hence such options should always be turned off.
Software like AdSubstract also blocks the referer and makes downloads impossible.
The latest ZoneAlarm also blocks Referers by default. Go to Privacy -> Cookie Control -> Custom and uncheck "remove private header information".
We're sorry for any inconvenience this may cause and hope you understand our reasons for doing so. Bandwith doesn't come cheap and we have to do all we can to keep the bandwith usage (roughly 600GB a month these days) down. -
http://mpucoder.kewlhair.com/Derrow/index.html
sometimes the site is down, keep trying.
Once you get there the downoad link is at the top, the latest version and previous versions. -
Br342
You probably have a download manager\accelorator on your computer. Many sites will not allow them access to their server. You need to un-install it or disable it if it can be disabled. -
I think doom9 uses referrers to prevent leeching. Just go to www.doom9.org and then navigate from there to the download section.
As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
Mirror_image is correct. You must go to their site cos they don't allow leeching.
Finding The Origin Of A Popup
By hech54 in forum ComputerReplies: 5Last Post: 27th Jun 2011, 10:40 -
Finding sound engineers?
By takearushfan in forum Off topicReplies: 3Last Post: 27th Dec 2010, 20:04 -
A little help finding the right ripper for me, please?
By Cygnus111 in forum DVD RippingReplies: 4Last Post: 9th May 2010, 11:27 -
Help finding ATSC STB
By TomTee in forum DVB / IPTVReplies: 30Last Post: 16th Sep 2007, 18:47 -
Another success in finding the obscure.
By AlecWest in forum Off topicReplies: 4Last Post: 7th May 2007, 22:11
