Ok, I'm sure this has been covered before, but I can't find it anywhere so I'll ask. I'm using an ATI AIW 128pro card to caprture from tv to MPEG 2. Things seemed to go alright during capture, I guess, with minimal dropped frames. Problem was with playback from the hard drive. Within 3-5 minutes of the beginning, the video and audio began to get out of synch and progressively got worse. Do I need to tweak my settings or am I missing something? Also, can I salvage this file and re-synch it somehow? All advice is appreciated.
NEWBIE
What do you mean "minimal drop of frames"? 1 in every 1000 frames, 1 in 10000? My experience is, if frame drop is less than 4-5 every 10000 frames, there should be no noticeable synch problem. Otherwise, it's very nasty to fix.
I just get it. You were doing real time mpeg-2 capture? That's a totally new animal to me. Never done it. Don't have a fast system. Maybe someone else can help you.
[Closed] Vid capture problem- aud/vid synch issues...?(Dazzle VidCreat+HD)
By Diana (Cda) in forum Capturing and VCRReplies: 2Last Post: 22nd Dec 2011, 10:50 -
Mpeg Streamclip synch issues
By filter5 in forum Video ConversionReplies: 1Last Post: 11th Aug 2008, 21:41 -
Audio At strat in Synch , along of Movie Lost Synch with Video !!!!!
By p_samimi in forum AudioReplies: 9Last Post: 12th Jan 2008, 23:47 -
SMPTE synch capture with audio
By deacea in forum Capturing and VCRReplies: 0Last Post: 1st Nov 2007, 12:22 -
h264 + ac3... .mkv mux in synch, .avi mux out of synch...
By homerpez in forum Video ConversionReplies: 0Last Post: 5th May 2007, 05:42
