Hello all,
I am struggling to capture my VHS collection to VCD.
I am using the PCTV Rave card. Unfortunately, I am not able to capture without problems (maybe the spec of my PC doesn't allow me to do so).
Some friends of mine told me that I have to buy hardware MPEG encoder (either MPEG1 or MPEG2 (SVCD)).
I took a look at capture card section of this site and mentioned that most of the cards (like Dazzle DVC) claim hardware encoding, but they're actually use software codec.
Would you be so please to give an advice about hardware codecs?
BTW, this is the spec of my machine:
P3-450, 128M, Banshee, 70GB (10+60), PCTV Rave, Live!.
Thanks,
TheRookie
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
For hardware encoders, if they're not about $1K+, then it's probably not worth getting.
Sure... Matrox RT2000, Pinnacle DC-1000/2000. I've seen video captured via the DC1000 and it is EXCELLENT quality.
Actually, the Dazzle DVC II is a hardware encoder/decoder card. As a consumer product, you get half decent SVCD out of it. if your pc is AMD/VIA may be trouble.
please read thread
http://www.vcdhelp.com/phpBB/viewtopic.php?topic=49085&forum=2&13
<font size=-1>[ This Message was edited by: Iview on 2001-07-05 03:31:13 ]</font> -
Hello,
The DVCII has a single pipe C-Cube (http://www.c-cube.com/) that does encoding at capture-time only. Decoding (aka playback) and editing is done through software.
The RT2x00 is a dual pipe C-Cube that does encoding at capture and editing. Decoding is done through software.
To get hardware decoding you need a card like the Dxr3 or Hollywood+. Other options are to have a video card with hardware assist (ex: ATI and NVidia GeForce).
Hardware MPEG-2 Capture Software ATI Theater 550 Pro
By CaZeek in forum CapturingReplies: 9Last Post: 22nd Nov 2010, 11:57 -
Best hardware capture card for Beyond TV
By videoguy01 in forum CapturingReplies: 0Last Post: 22nd Feb 2009, 13:39 -
Card with mpeg-2 hardware capturing for standard definition?
By Giantsloth in forum CapturingReplies: 3Last Post: 27th Oct 2008, 18:26 -
Can't Burn from Mpeg-2 to DVD (Nero Software & Pinnacle Capture Card)
By bpatters69 in forum Authoring (DVD)Replies: 14Last Post: 9th Nov 2007, 07:35 -
Using Capture/Recoding PCI card - GV-650 Video Capture Card
By Confused Chimp in forum CapturingReplies: 1Last Post: 6th May 2007, 17:15
